Ga door naar hoofdinhoud
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
Wat je nodig hebt
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: stap 1, afbeelding 1 van 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: stap 1, afbeelding 2 van 2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: stap 2, afbeelding 1 van 1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: stap 3, afbeelding 1 van 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: stap 3, afbeelding 2 van 2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Conclusie
Thomas Eggenberger
139 Reputatie
1 Handleiding geschreven
Cal Poly, Team S11-G4, Banghart Winter 2018 Lid van Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Leden
10 handleidingen geschreven
Één opmerking
Thank you, made it easy peasy!
J Colee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 106
Altijd: 8,807
