Ga door naar hoofdinhoud
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
Wat je nodig hebt
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: stap 1, afbeelding 1 van 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: stap 1, afbeelding 2 van 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: stap 1, afbeelding 3 van 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: stap 2, afbeelding 1 van 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Conclusie
Sophia Stockburger
566 Reputatie
5 handleidingen geschreven
Cal Poly, Team S11-G2, Banghart Winter 2018 Lid van Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Leden
9 handleidingen geschreven
3 opmerkingen
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Antwoord
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 996
