Inleiding
This guide will show you how to open dissemble the handle and replace the motherboard. You might need to do this if the device has power but fails to turn on. Remember to remove the battery from the device.
Wat je nodig hebt
Remove the single 15mm Phillips #1 screw from the handle.
Remove the black rubber cover from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
