Ga door naar hoofdinhoud
Honeywell HYF260BV2 Main Board Replacement
Wat je nodig hebt
  1. Honeywell HYF260BV2 Main Board Replacement, Main Board: stap 1, afbeelding 1 van 2 Honeywell HYF260BV2 Main Board Replacement, Main Board: stap 1, afbeelding 2 van 2
    • Unplug your fan and place it on its side.
    • Twist the red plastic piece off from the bottom.
    • Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
  2. Honeywell HYF260BV2 Main Board Replacement: stap 2, afbeelding 1 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 2, afbeelding 2 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 2, afbeelding 3 van 3
    • Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
  3. Honeywell HYF260BV2 Main Board Replacement: stap 3, afbeelding 1 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 3, afbeelding 2 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 3, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
  4. Honeywell HYF260BV2 Main Board Replacement: stap 4, afbeelding 1 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 4, afbeelding 2 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 4, afbeelding 3 van 3
    • Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
    • Do this gently because you could break the connectors for the back of the fan.
  5. Honeywell HYF260BV2 Main Board Replacement: stap 5, afbeelding 1 van 1
    • Pull off the back of the fan and set it aside.
    • Dust the inside of the fan if it is needed.
    • Be careful when dusting and ensure nothing is knocked out of place.
  6. Honeywell HYF260BV2 Main Board Replacement: stap 6, afbeelding 1 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 6, afbeelding 2 van 3 Honeywell HYF260BV2 Main Board Replacement: stap 6, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
    • Remove the two larger 14 mm Phillips #1 screws located below.
    • Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
  7. Honeywell HYF260BV2 Main Board Replacement: stap 7, afbeelding 1 van 1
    • Pull the gray cover from the fan to reveal the main board.
  8. Honeywell HYF260BV2 Main Board Replacement: stap 8, afbeelding 1 van 1
    • Carefully hold the edges of the main board and slowly pull it out.
  9. Honeywell HYF260BV2 Main Board Replacement: stap 9, afbeelding 1 van 2 Honeywell HYF260BV2 Main Board Replacement: stap 9, afbeelding 2 van 2
    • Unplug the main board.
    • Follow the cables connected to the board to the bottom of the fan.
  10. Honeywell HYF260BV2 Main Board Replacement: stap 10, afbeelding 1 van 2 Honeywell HYF260BV2 Main Board Replacement: stap 10, afbeelding 2 van 2
    • Unplug the connector to disconnect the bundle of wires.
    • Use scissors to cut the zip tie that secures the wires.
    • Be careful when you cut the zip tie so that you don't accidentally cut the wires.
  11. Honeywell HYF260BV2 Main Board Replacement: stap 11, afbeelding 1 van 1
    • Pull the wires up and slide them out of the fan to replace the main board with a new one.
Conclusie
Joshua Moreno
193 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 50
