Ga door naar hoofdinhoud
Honeywell HY-254-TGT Front Panel Replacement
Wat je nodig hebt
  1. Honeywell HY-254-TGT Front Panel Replacement, Plastic Assembly: stap 1, afbeelding 1 van 1
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Front Panel Replacement: stap 2, afbeelding 1 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 2, afbeelding 2 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 2, afbeelding 3 van 3
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Front Panel Replacement: stap 4, afbeelding 1 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 4, afbeelding 2 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Front Panel Replacement, Front Panel: stap 5, afbeelding 1 van 2 Honeywell HY-254-TGT Front Panel Replacement, Front Panel: stap 5, afbeelding 2 van 2
    • Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
    • Lean the front panel forwards and set it down.
    • The front panel will not fully detach and cannot be removed. Do not try to forcibly remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Front Panel Replacement: stap 6, afbeelding 1 van 2 Honeywell HY-254-TGT Front Panel Replacement: stap 6, afbeelding 2 van 2
    • Gently lift and remove the panel covering the electronics assembly.
  7. Honeywell HY-254-TGT Front Panel Replacement: stap 7, afbeelding 1 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 7, afbeelding 2 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 7, afbeelding 3 van 3
    • Remove the four 1/2" Phillips #01 screws in the circuit board.
    • Gently pull the circuit board off of the rest of the front panel assembly.
  8. Honeywell HY-254-TGT Front Panel Replacement: stap 8, afbeelding 1 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 8, afbeelding 2 van 3 Honeywell HY-254-TGT Front Panel Replacement: stap 8, afbeelding 3 van 3
    • Lift out the internal part of the front panel to access the buttons.
  9. Honeywell HY-254-TGT Front Panel Replacement: stap 9, afbeelding 1 van 1
    • If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
    • Upon reassembly, ensure buttons are placed in the correct location.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Darian Maxwell
381 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-6, Forte Fall 2015 Lid van Cal Poly, Team 11-6, Forte Fall 2015
CPSU-FORTE-F15S11G6
4 Leden
4 handleidingen geschreven
2 opmerkingen
the piece to make it turn is broken
clara rojas - Antwoord
the piece that make it turn is broken!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 5,442
