Ga door naar hoofdinhoud
Honeywell HT900C Motor Replacement
Wat je nodig hebt
  1. Honeywell HT900C Motor Replacement, Motor: stap 1, afbeelding 1 van 3 Honeywell HT900C Motor Replacement, Motor: stap 1, afbeelding 2 van 3 Honeywell HT900C Motor Replacement, Motor: stap 1, afbeelding 3 van 3
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: stap 2, afbeelding 1 van 3 Honeywell HT900C Motor Replacement: stap 2, afbeelding 2 van 3 Honeywell HT900C Motor Replacement: stap 2, afbeelding 3 van 3
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: stap 3, afbeelding 1 van 2 Honeywell HT900C Motor Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: stap 4, afbeelding 1 van 3 Honeywell HT900C Motor Replacement: stap 4, afbeelding 2 van 3 Honeywell HT900C Motor Replacement: stap 4, afbeelding 3 van 3
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: stap 5, afbeelding 1 van 3 Honeywell HT900C Motor Replacement: stap 5, afbeelding 2 van 3 Honeywell HT900C Motor Replacement: stap 5, afbeelding 3 van 3
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: stap 6, afbeelding 1 van 2 Honeywell HT900C Motor Replacement: stap 6, afbeelding 2 van 2
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: stap 8, afbeelding 1 van 2 Honeywell HT900C Motor Replacement: stap 8, afbeelding 2 van 2
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: stap 9, afbeelding 1 van 1
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Duy Anh Nguyen
169 Reputatie
1 Handleiding geschreven
York University, Team B-10, Allen Fall 2022 Lid van York University, Team B-10, Allen Fall 2022
YORK-ALLEN-F22SBG10
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 936
