Inleiding
This guide shows how to remove and replace the rotary tine oil seals on a Honda FRC800K1A Rear Tine Tiller.
Drain the oil from the transmission before beginning this process.
After completing this procedure, refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Wat je nodig hebt
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use a 12 mm socket and wrench to remove the six sets of side guard bolts and nuts, three on each side.
Use a 14 mm socket to remove the two rotary tine retaining bolts.
Wedge a large flathead screwdriver underneath the metal lip on the oil seal.
Firmly pry the seal away from the transmission.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
