Inleiding
Use this guide to replace the throttle cable in a Honda Light Duty Tiller F220K1AT715492.
Wat je nodig hebt
Pull the spark plug connector straight off of the spark plug.
Push down on the two tabs at the top of the air filter cover.
With the two tabs depressed, swing the top of the cover down.
Remove the cover.
Use an 8 mm socket to remove the following fasteners securing the air cleaner housing:
Two silver nuts
One black bolt
Slide the pink breather tube out of its clip on the back of the air cleaner housing.
Hold the black carburetor hose in place and rotate the air cleaner housing clockwise until you can slide the hose out of its slot on the air cleaner housing.
Remove the air cleaner housing.
Use an 8 mm wrench to hold the throttle cable barrel adjuster in place while you use a 10 mm wrench to loosen the lock nut.
Continue to loosen the lock nut until it is against the end of the threads.
With the lock nut against the end of the threads, tighten the barrel until it is against the lock nut to add as much slack as possible to the cable.
Lift the throttle cable straight up and slide it through the slot on the throttle control.
Één andere persoon heeft deze handleiding voltooid.
