Wat je nodig hebt
Turn the key in the ignition to the run position (right before the start position)
Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
You did it!
You did it!
19 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Great. I did it—and I’m a girl!!
Excellent! Glad to hear it.
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
And how can I start the car that it won't start
Have you tried changing your blinker fluid?
neegnorg -
