Ga door naar hoofdinhoud
Honda Fit Reset Oil Life Indicator Replacement
Wat je nodig hebt
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
Conclusie
You did it!
19 andere personen hebben deze handleiding voltooid.
Jasen Friedle
3.821 Reputatie
3 handleidingen geschreven
5 opmerkingen
Great. I did it—and I’m a girl!!
pthompso99 - Antwoord
Excellent! Glad to hear it.
Jasen Friedle - Antwoord
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Antwoord
And how can I start the car that it won't start
sbukataake - Antwoord
Have you tried changing your blinker fluid?
neegnorg -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 102
Afgelopen 30 dagen: 515
Altijd: 75,032
