Inleiding
Follow this guide to replace a worn or damaged throttle cable on the Honda FC600 tiller. Be sure to follow all safety precautions listed in the tiller’s user manual when working on or operating the machine.
Wat je nodig hebt
Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
Use your fingers to unscrew and remove the wing nut securing the air filter cover to the air filter elbow.
Squeeze the metal clip on the inside of the air filter cover and remove it.
Use your fingers to unscrew and remove the wing nut securing the air filter to the air filter elbow.
Use a 10 mm socket and socket wrench to remove the 25.5 mm-long bolt securing the air filter elbow to the tiller.
Insert a flathead screwdriver in between the release tab and the tip of the cable tie securing the throttle cable to the handlebar.
Twist the screwdriver to separate the release tab and loosen the cable tie.
Één andere persoon heeft deze handleiding voltooid.
