Inleiding
If the case of the shear is cracked and you are concerned about debris getting into the device this guide is what you are looking for.
Wat je nodig hebt
Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
Pull the faceplate away from the body of the device and replace it with the new faceplate.
Bijna klaar!
Conclusie
