Ga door naar hoofdinhoud
Homedics UHE-CMP15 Water Replacement
Wat je nodig hebt
  1. Homedics UHE-CMP15 Water Replacement, Water: stap 1, afbeelding 1 van 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
  2. Homedics UHE-CMP15 Water Replacement: stap 2, afbeelding 1 van 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
  3. Homedics UHE-CMP15 Water Replacement: stap 3, afbeelding 1 van 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
  4. Homedics UHE-CMP15 Water Replacement: stap 4, afbeelding 1 van 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
Conclusie
Dylan
337 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-6, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 160
