Ga door naar hoofdinhoud
Homedics UHE-CMP15 Charging Cable Cleaning
Wat je nodig hebt
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: stap 1, afbeelding 1 van 2 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: stap 1, afbeelding 2 van 2
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: stap 2, afbeelding 1 van 2 Homedics UHE-CMP15 Charging Cable Cleaning: stap 2, afbeelding 2 van 2
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: stap 3, afbeelding 1 van 1
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
Conclusie
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
267 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-6, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 126
