Ga door naar hoofdinhoud
Homedics UHE-CMP15 Battery Replacement
Wat je nodig hebt
  1. Homedics UHE-CMP15 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
    • Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
  2. Homedics UHE-CMP15 Battery Replacement: stap 2, afbeelding 1 van 1
    • Flip the top portion upside down and remove the wick and wick holder.
    • To remove the wick pull on the wick holder and it should pop right off.
  3. Homedics UHE-CMP15 Battery Replacement: stap 3, afbeelding 1 van 2 Homedics UHE-CMP15 Battery Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers and or the spudging tool lift 3 small white rubber caps, pry underneath them and pull to remove them.
    • This reveals the three screws holding the cap in place.
  4. Homedics UHE-CMP15 Battery Replacement: stap 4, afbeelding 1 van 1
    • Unscrew and remove the 3 screws with a Philips head screwdriver. The screwdriver must be very long and thin.
    • Tilting the device upside down will slide the unscrewed screws out from the holes they are in after they are loosened.
  5. Homedics UHE-CMP15 Battery Replacement: stap 5, afbeelding 1 van 3 Homedics UHE-CMP15 Battery Replacement: stap 5, afbeelding 2 van 3 Homedics UHE-CMP15 Battery Replacement: stap 5, afbeelding 3 van 3
    • The top portion will now be able to be removed to reveal the inside of the battery compartment.
    • The battery is glued to the side wall with an adhesive pad.
    • This battery is hardwired in, and will require skill in soldering/wiring and the ability to find a suitable replacement.
Conclusie
Kade Betterton
267 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-6, Konn Fall 2023 Lid van UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 278
