Ga door naar hoofdinhoud
HomePod Mini speaker Replacement
Wat je nodig hebt
    • turn homepod mini upside down
    • peel back the foot cover
    • carefully cut the fabric mesh using the fabric scissors
    • be very careful not to scratch the delicate glass surface on top
    • unscrew the 4 torx screws on the bottom near the speaker holes
    • carefully seperate the top and middle sections from the homepod mini
    • be very careful when separating as there are cables connected to the motherboard as well as the speakers
    • carefully unplug all the cables connected to the motherboard
    • carefully separate the middle section of the homepod mini
    • carefully remove the speaker driver from the bottom part of the homepod mini
    • be very careful not to damage the delicate ribbon cable below the driver
    • remove the speaker driver
    • carefully remove the cables connecting to the driver being careful not to damage it
Conclusie
776831
1.095 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 79
Altijd: 306
