Inleiding
How to replace the rear right arm of the Holy Stone HS720 Drone.
Soldering is required
Video is being worked on
The other arms on the drone have different soldering points, so this only applies to the rear right arm.
Wat je nodig hebt
Press down on the button and pull out the battery, to reveal 2 hidden screws.
Remove the 2 screws located under the battery
Remove the 2 screws on the sides of the drone, one on each side
Gently pry on the top plastic cover to gain access to the main board.
There are 2 cables running from the back of the cover, do not accidentally tear them
Unplug the 2 cables, by gently prying on them, and remove the top cover of the drone
Look closely at the images and locate the 7 wires that are connected to the arm
Take a photo of the board, so that you can resolder them back correctly later
Desolder the 7 wires
Remove the 2 screws that attach the rear right foot of the drone
Take the foot off, to reveal the arm spring
Pry out the white plastic piece, to free the arm. (note: there are no screws holding it in)
Slowly pull the arm out, along with the wires connected to it
Hope this helped :)
Hope this helped :)
Één andere persoon heeft deze handleiding voltooid.
