Ga door naar hoofdinhoud
Holmes HEH8031 Safety Weight Replacement
Wat je nodig hebt
  1. Holmes HEH8031 Safety Weight Replacement, Housing: stap 1, afbeelding 1 van 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: stap 2, afbeelding 1 van 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: stap 3, afbeelding 1 van 2 Holmes HEH8031 Safety Weight Replacement: stap 3, afbeelding 2 van 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: stap 4, afbeelding 1 van 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: stap 5, afbeelding 1 van 2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: stap 5, afbeelding 2 van 2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Conclusie
Deanna Jack
333 Reputatie
4 handleidingen geschreven
IUPUI, Team 2-1, Baechle Fall 2016 Lid van IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 553
