Ga door naar hoofdinhoud
Holmes HEH8031 Power Cord Replacement
Wat je nodig hebt
  1. Holmes HEH8031 Power Cord Replacement, Housing: stap 1, afbeelding 1 van 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: stap 3, afbeelding 1 van 2 Holmes HEH8031 Power Cord Replacement: stap 3, afbeelding 2 van 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: stap 4, afbeelding 1 van 3 Holmes HEH8031 Power Cord Replacement, Power Cord: stap 4, afbeelding 2 van 3 Holmes HEH8031 Power Cord Replacement, Power Cord: stap 4, afbeelding 3 van 3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: stap 5, afbeelding 1 van 3 Holmes HEH8031 Power Cord Replacement: stap 5, afbeelding 2 van 3 Holmes HEH8031 Power Cord Replacement: stap 5, afbeelding 3 van 3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: stap 6, afbeelding 1 van 2 Holmes HEH8031 Power Cord Replacement: stap 6, afbeelding 2 van 2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Deanna Jack
345 Reputatie
4 handleidingen geschreven
IUPUI, Team 2-1, Baechle Fall 2016 Lid van IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Leden
16 handleidingen geschreven
Één opmerking
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 2,094
