Ga door naar hoofdinhoud
Holmes HEH8031 Control Buttons Replacement
Wat je nodig hebt
  1. Holmes HEH8031 Control Buttons Replacement, Housing: stap 1, afbeelding 1 van 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: stap 3, afbeelding 1 van 2 Holmes HEH8031 Control Buttons Replacement: stap 3, afbeelding 2 van 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: stap 4, afbeelding 1 van 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: stap 5, afbeelding 1 van 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: stap 5, afbeelding 2 van 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: stap 5, afbeelding 3 van 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: stap 6, afbeelding 1 van 3 Holmes HEH8031 Control Buttons Replacement: stap 6, afbeelding 2 van 3 Holmes HEH8031 Control Buttons Replacement: stap 6, afbeelding 3 van 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chris Shaffer
255 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-1, Baechle Fall 2016 Lid van IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 469
