Ga door naar hoofdinhoud
Holley 4 Barrel Carburetor Gasket Replacement
Wat je nodig hebt
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: stap 1, afbeelding 1 van 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: stap 1, afbeelding 2 van 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: stap 1, afbeelding 3 van 3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: stap 3, afbeelding 1 van 1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: stap 5, afbeelding 1 van 1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: stap 6, afbeelding 1 van 2 Holley 4 Barrel Carburetor Gasket Replacement: stap 6, afbeelding 2 van 2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: stap 7, afbeelding 1 van 1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: stap 8, afbeelding 1 van 1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: stap 9, afbeelding 1 van 2 Holley 4 Barrel Carburetor Gasket Replacement: stap 9, afbeelding 2 van 2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 60
Altijd: 4,393
