Inleiding
Krassen in brillenglazen kunnen ervoor zorgen dat je er moeilijk doorheen kunt kijken. Gelukkig kunnen krassen worden verholpen om je bril er weer als nieuw uit te laten zien. Houd je bril schoon en vrij van vlekken in deze paar eenvoudige stappen.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Plaats de bril, wax en doek op een vlakke ondergrond.
Voor bijzonder diepe of hardnekkige krassen herhaalt u deze stappen totdat de kras is gerepareerd.
45 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Toon Konings helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
18 Opmerkingen
Stupid is as stupid does! Think about it. A scratch is a certain width, when you polish it you are just grinding off the edges of the scratch and actually making it wider. So unless you are capable of removing all the surrounding material to the depth of the deepest part of the scratch AND maintaining the profile to within a very very small tolerance then this just WILL NOT work. Filling the scratch with wax cannot work either as wax does not have the same refractive index as the lens material. Conclusion: take care of your glasses and if you are careless enough to damage them it's your own fault, accept responsibility and replace them.
This sounds like "I've not tried this but I've thought about it for a few minutes and this is what I think will happen". Very short on evidence.
steve -
Wow!!! Just couldn’t help yourself could you. Perhaps you’ve heard “If you can’t say something nice say nothing at all”! Grow up without doing it at someone elses expense.
Yaya -
Obviously, this person has never made a mistake and is absolutely perfect in every way.
