Inleiding
If your humidifier is making loud noises or is not releasing mist, follow this guide to access the fan. This guide is an easy step-by-step process of how to remove your fan for a simple replacement. For this guide, you will need a Phillips #1 screwdriver head to remove and replace the fan.
Wat je nodig hebt
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Bijna klaar!
Conclusie
