Ga door naar hoofdinhoud
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
Wat je nodig hebt
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: stap 1, afbeelding 1 van 1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: stap 2, afbeelding 1 van 1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: stap 3, afbeelding 1 van 1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Conclusie
Mike
397 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-2, Banghart Winter 2017 Lid van Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Leden
7 handleidingen geschreven
Één opmerking
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 406
