Inleiding
This guide will show you how to disassemble the projector acting as a supplemental guide for the other replacement guides for this device. Many of the parts that may need replacing in the projector require the device to be disassembled.
Before beginning disassembly, be sure the projector is unplugged from any outlets.
Wat je nodig hebt
Turn the projector upside down so the bottom is facing up.
Remove the 6 black 2 cm screws with a Phillips #1 Screwdriver.
