Inleiding
The lamp is the most essential part of the projector because it shines the light your projector uses to display vivid images. If the image is excessively dim or not backlit at all, replacing the lamp may be necessary.
Follow this guide to replace the lamp of your Hitachi CP-X2010N projector.
Before handling the lamp, ensure the device is powered off and unplugged. Also make sure that the projector has cooled off if it has recently been used, as it could become warm after prolonged use.
Wat je nodig hebt
Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
Using a Phillips #2 screwdriver, loosen three silver captive screws from lamp housing.
4 andere personen hebben deze handleiding voltooid.
