Ga door naar hoofdinhoud
Hisense Sero 7 Pro Battery Replacement
Wat je nodig hebt
  1. Hisense Sero 7 Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Hisense Sero 7 Pro Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Battery Replacement: stap 2, afbeelding 1 van 2 Hisense Sero 7 Pro Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Battery Replacement: stap 3, afbeelding 1 van 2 Hisense Sero 7 Pro Battery Replacement: stap 3, afbeelding 2 van 2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
Conclusie
Baochau Nguyen
314 Reputatie
3 handleidingen geschreven
Texas Tech, Team 38-2, Bennett Fall 2016 Lid van Texas Tech, Team 38-2, Bennett Fall 2016
TTU-BENNETT-F16S38G2
4 Leden
6 handleidingen geschreven
2 opmerkingen
would be nice to actually have replacement battery avaible to buy new battery
howlingwolff10 - Antwoord
Where could one buy new battery?
Joshua Wood - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 2,677
