Ga door naar hoofdinhoud
Hipstreet Titan 2 HD Rear Case Replacement
Wat je nodig hebt
  1. Hipstreet Titan 2 HD Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Rear Case Replacement: stap 4, afbeelding 1 van 2 Hipstreet Titan 2 HD Rear Case Replacement: stap 4, afbeelding 2 van 2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Rear Case Replacement: stap 5, afbeelding 1 van 2 Hipstreet Titan 2 HD Rear Case Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Rear Case Replacement: stap 6, afbeelding 1 van 1
    • Once the speaker is disconnected, the cover removal is complete.
Conclusie
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Jeffrey
766 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 5-6, Panko Spring 2015 Lid van Colorado Springs, Team 5-6, Panko Spring 2015
UCCS-PANKO-S15S5G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 616
