Inleiding
Users must disassemble the front cover to replace the battery. A replacement battery will be needed. This is a difficult process for users who do not have experience with soldering connections.
Wat je nodig hebt
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Remove the black placement tape from the battery.
Find the two battery solder connections on the circuit board.
Één andere persoon heeft deze handleiding voltooid.
