Inleiding
The HiKOKI H60ME demolition hammer is a robust tool that is used on many construction sites. However, like any tool, it can experience wear and tear over time, necessitating repairs. In this guide, we will show you how to open the handle of the HiKOKI H60ME demolition hammer to perform repairs or maintenance work.
Wat je nodig hebt
Lay the device on its side so that you have access to the screws.
The device has the following types of screws:
4x Phillips screws
1x 4mm Hex
Loosen the 4 Phillips screws.
Loosen the hex screw with a 4mm hex key.
Work through the steps in reverse, to assemble your device again.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
