Ga door naar hoofdinhoud
Heyday Wireless Speaker 8125 Battery Replacement
Wat je nodig hebt
  1. Heyday Wireless Speaker 8125 Battery Replacement, Grille: stap 1, afbeelding 1 van 3 Heyday Wireless Speaker 8125 Battery Replacement, Grille: stap 1, afbeelding 2 van 3 Heyday Wireless Speaker 8125 Battery Replacement, Grille: stap 1, afbeelding 3 van 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
  2. Heyday Wireless Speaker 8125 Battery Replacement, Black Plastic Cover: stap 2, afbeelding 1 van 2 Heyday Wireless Speaker 8125 Battery Replacement, Black Plastic Cover: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the four black rubber screw covers.
    • Use a Phillips screwdriver to remove four 8.9 mm screws underneath the screw covers.
    • Once all four screws are out, gently pull the black cover out using your hands or use a spudger to pry it out.
    • The cover is attached to the motherboard beneath by the speaker cable. Don't yank the cover from the device. You will need to detach the connector from the socket before removing it entirely.
  3. Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: stap 3, afbeelding 1 van 3 Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: stap 3, afbeelding 2 van 3 Heyday Wireless Speaker 8125 Battery Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove four 6.6 mm screws from the motherboard.
    • Lift the motherboard out of the speaker gently.
    • It's attached below by a couple of cables, so don't pull it out.
  4. Heyday Wireless Speaker 8125 Battery Replacement: stap 4, afbeelding 1 van 2 Heyday Wireless Speaker 8125 Battery Replacement: stap 4, afbeelding 2 van 2
    • Pull each cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the motherboard from the device.
  5. Heyday Wireless Speaker 8125 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Heyday Wireless Speaker 8125 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove three 6.6 mm screws from the triangular plastic support.
    • Lift the plastic support to reveal the battery underneath.
  6. Heyday Wireless Speaker 8125 Battery Replacement: stap 6, afbeelding 1 van 2 Heyday Wireless Speaker 8125 Battery Replacement: stap 6, afbeelding 2 van 2
    • Use an opening tool or plastic spudger to gently pry the battery from the bottom of the device.
    • The battery is held down with adhesive so it will take a bit of work to remove.
    • Don't bend or puncture the battery in the process. Batteries can cause a fire or worse if damaged.
    • Remove the battery.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 328
