Ga door naar hoofdinhoud
Heyday Wireless Bluetooth Speaker 9979 Battery Replacement
Wat je nodig hebt
  1. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement, Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 1, afbeelding 1 van 1
    • Remove the four bezels from the speaker's back cover.
    • Try to get under the bezel by using force, and pull it out little by little.
  2. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the four 1.6 mm screws. Rotate the driver counterclockwise to remove the screws.
  3. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 3, afbeelding 1 van 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the cover of the wireless speaker using the metal spudger. Don't use much force to remove it.
  4. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 4, afbeelding 1 van 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 4, afbeelding 2 van 2
    • Once you have pulled the cover to the side, remove the two screws with a Philips #000 screwdriver. Turn counterclockwise.
  5. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 5, afbeelding 1 van 2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 5, afbeelding 2 van 2
    • The battery might be glued down so use the black nylon spundger to take it out completely.
  6. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 6, afbeelding 1 van 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 6, afbeelding 2 van 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 6, afbeelding 3 van 3
    • Using the nylon tipped tweezers, remove the motherboard carefully. It is recommended to grab the motherboard in the middle as there are no big buttons on it.
  7. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 7, afbeelding 1 van 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 7, afbeelding 2 van 3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: stap 7, afbeelding 3 van 3
    • You want to remove the white power cable connector from the motherboard. Start by using the fixit opening pick to pull it up. Once it is almost out, use you're fingers to just simply disconnect it.
Conclusie
Thanh Duong
195 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-4, Adachi Fall 2022 Lid van CSU Los Angeles, Team 5-4, Adachi Fall 2022
CSULA-ADACHI-F22S5G4
5 Leden
2 handleidingen geschreven
4 opmerkingen
The grammar could be improved by simplifying the steps (not using too many words or try separating into multiple bullet points) and avoiding the use of ambiguous pronouns (it).
Jadealyn Paulino - Antwoord
Will do, thanks!
Chris Yepez -
There are a lot of images and some are the same.
Cindy Munoz - Antwoord
The description of each tool needed was a very useful touch.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 461
