Ga door naar hoofdinhoud
Heyday True Wireless Earbuds 8204 Case Motherboard Replacement
Wat je nodig hebt
  1. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement, Case Motherboard: stap 1, afbeelding 1 van 1
    • Use a spudger or other prying tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
    • Screwdrivers shouldn't be used as pry tools as they can damaged delicate internal components.
  2. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using the spudger, going from the back of the case where the hinge used to be, pry the earbud charging housing up and remove it.
  3. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a Torx screwdriver to gently remove the six screws on the silver ring that holds in the motherboard and charging station.
  4. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Pull the silver bracket from the base of the case to reveal the motherboard.
    • Lift up and pull the motherboard out of the case.
Conclusie
Ben Davignon
493 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-3, Petersen Fall 2022 Lid van UMass Dartmouth, Team 1-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G3
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 148
