Ga door naar hoofdinhoud
Heyday Suitcase Turntable Baseboard Removal
Wat je nodig hebt
  1. Heyday Suitcase Turntable Baseboard Removal, Baseboard: stap 1, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Baseboard Removal: stap 2, afbeelding 1 van 1
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Baseboard Removal: stap 3, afbeelding 1 van 2 Heyday Suitcase Turntable Baseboard Removal: stap 3, afbeelding 2 van 2
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
Conclusie
To reassemble your device, follow these instructions in reverse order. Reconnect the cords to their appropriate ports on the circuit board, then replace the baseboard by tightening the four screws.
Caroline D'Amato
565 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 138
