Ga door naar hoofdinhoud
Herringbone Stitch on a Split Seam
Wat je nodig hebt
    1. Herringbone Stitch on a Split Seam, Intro to the herringbone stitch: stap 1, afbeelding 1 van 2 Herringbone Stitch on a Split Seam, Intro to the herringbone stitch: stap 1, afbeelding 2 van 2
      • Structure - The herringbone stitch consists of a series of alternating slanted stitches, creating a crosshatch pattern.
      • Repair Use - This stitch provides excellent stretch, making it ideal for knit and stretch fabrics. It's effective when fabric edges touch or slightly overlap, making it a strong choice for repairing damaged coverstitch seams.
      Vraag FixBot
      Voeg opmerking toe
    2. Herringbone Stitch on a Split Seam, Assess the damage: stap 2, afbeelding 1 van 3 Herringbone Stitch on a Split Seam, Assess the damage: stap 2, afbeelding 2 van 3 Herringbone Stitch on a Split Seam, Assess the damage: stap 2, afbeelding 3 van 3
      • Locate the damaged area and trim away any loose or hanging threads.
      • If necessary, pin the seam together so that it stays in place during stitching.
      Vraag FixBot
      Voeg opmerking toe
    3. Herringbone Stitch on a Split Seam, Plan the stitch: stap 3, afbeelding 1 van 2 Herringbone Stitch on a Split Seam, Plan the stitch: stap 3, afbeelding 2 van 2
      • The herringbone stitch follows two parallel lines, with the thread creating a crisscross pattern between them.
      • Before beginning, determine:
      • Stitch Width - The distance between the two parallel stitch lines. Mark both lines with chalk or heat-erasable pen.
      • Diagonal Stitch Length - The length of the diagonal stitch moving from one stitch line to the other that creates the crosshatch pattern.
      • Backstitch Length - The length of the small backstitch that secures each diagonal stitch.
      • These measurements will determine the structure and appearance of the herringbone stitch.
      Vraag FixBot
      Voeg opmerking toe
    4. Herringbone Stitch on a Split Seam, Start the stitch: stap 4, afbeelding 1 van 3 Herringbone Stitch on a Split Seam, Start the stitch: stap 4, afbeelding 2 van 3 Herringbone Stitch on a Split Seam, Start the stitch: stap 4, afbeelding 3 van 3
      • Thread the needle with a length of thread approximately 24 inches (~61 cm) and tie a knot at one end of the thread. For more details see Needles and Thread.
      • In the pictured repair, embroidery floss is used for visibility.
      • From the backside, insert the needle through to the front at a marked stitch line. Overlap any existing stitching by at least 1/2 inch (~13 mm).
      • In the pictured repair, remnant stitch lines from a missing coverstitch will be followed.
      • Pull the thread through until the knot lies flush against the back of the fabric.
      Vraag FixBot
      Voeg opmerking toe
    5. Herringbone Stitch on a Split Seam, Make a diagonal stitch: stap 5, afbeelding 1 van 3 Herringbone Stitch on a Split Seam, Make a diagonal stitch: stap 5, afbeelding 2 van 3 Herringbone Stitch on a Split Seam, Make a diagonal stitch: stap 5, afbeelding 3 van 3
      • On the front side, move the needle diagonally across the seam in the direction of the stitch path.
      • Insert the needle into the opposing stitch line at the Diagonal Stitch Length determined in Step 3.
      • Make a small stitch backwards along the marked stitch line with the Backstitch Length determined in Step 3.
      • If sewing through two layers, ensure both fabric layers are caught in the backstitch.
      • Pull the thread through.
      Vraag FixBot
      Voeg opmerking toe
    6. Herringbone Stitch on a Split Seam, Continue the stitch: stap 6, afbeelding 1 van 2 Herringbone Stitch on a Split Seam, Continue the stitch: stap 6, afbeelding 2 van 2
      • Move diagonally across the seam again.
      • Insert the needle, make a backstitch, and pull the thread through.
      • Keep the Stitch Width, Diagonal Stitch Length and the Backstitch Length consistent to create an even, durable stitch pattern.
      Vraag FixBot
      Voeg opmerking toe
    7. Herringbone Stitch on a Split Seam, Continue the stitch: stap 7, afbeelding 1 van 2 Herringbone Stitch on a Split Seam, Continue the stitch: stap 7, afbeelding 2 van 2
      • Repeat the diagonal and backstitch sequence, forming a crisscross pattern along the seam.
      • Continue stitching until the repair extends at least 1/2 inch (~13 mm) beyond the damaged area.
      Vraag FixBot
      Voeg opmerking toe
    8. Herringbone Stitch on a Split Seam, Tie off the thread: stap 8, afbeelding 1 van 3 Herringbone Stitch on a Split Seam, Tie off the thread: stap 8, afbeelding 2 van 3 Herringbone Stitch on a Split Seam, Tie off the thread: stap 8, afbeelding 3 van 3
      • To complete the stitch, move the needle to the backside and make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways).
      Vraag FixBot
      Voeg opmerking toe
    9. Herringbone Stitch on a Split Seam, Quality check: stap 9, afbeelding 1 van 2 Herringbone Stitch on a Split Seam, Quality check: stap 9, afbeelding 2 van 2
      • Ensure the stitches have effectively secured the seam.
      • For additional strength and coverage, repeat these steps to add another stitch line.
      • Placing the new stitch staggered from the original can create an appealing design.
      • Creating more compact stitches will also create a more durable stitch.
      Vraag FixBot
      Voeg opmerking toe
      • THREAD TENSION: Consistent thread tension is essential for a durable and flexible herringbone stitch. If the stitches are too tight, the fabric may pucker. If the stitches are too loose, the repair may lack stability.
      • Check the tension frequently while stitching, especially when repairing a slit or split seam, where fabric edges may shift.
      • Adjust as needed by gently pulling or loosening the thread to ensure the stitches lie flat without distorting the fabric.
      • Pause periodically to smooth the fabric and confirm the stitch tension is even along the repair.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Clara Redwood
2.568 Reputatie
19 handleidingen geschreven
Patagonia Lid van Patagonia
Community
9 Leden
344 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 146
Altijd: 1,289
