Ga door naar hoofdinhoud
Health o Meter HDR743 Power Supply Replacement
Wat je nodig hebt
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: stap 1, afbeelding 1 van 1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: stap 2, afbeelding 1 van 1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: stap 3, afbeelding 1 van 1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: stap 4, afbeelding 1 van 2 Health o Meter HDR743  Power Supply Replacement: stap 4, afbeelding 2 van 2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Conclusie
Dennis White Jr
217 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 154
