Ga door naar hoofdinhoud
Headphone Jack
Wat je nodig hebt
  1. Headphone Jack, Battery: stap 1, afbeelding 1 van 1
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: stap 2, afbeelding 1 van 1
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: stap 3, afbeelding 1 van 2 Headphone Jack: stap 3, afbeelding 2 van 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: stap 4, afbeelding 1 van 1
    • Pull battery out.
  5. Headphone Jack, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: stap 6, afbeelding 1 van 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: stap 7, afbeelding 1 van 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: stap 8, afbeelding 1 van 1
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: stap 9, afbeelding 1 van 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: stap 10, afbeelding 1 van 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: stap 11, afbeelding 1 van 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: stap 12, afbeelding 1 van 3 Headphone Jack: stap 12, afbeelding 2 van 3 Headphone Jack: stap 12, afbeelding 3 van 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: stap 13, afbeelding 1 van 1
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: stap 14, afbeelding 1 van 1
    • Use plastic pry tool to lift up on headphone jack assembly
Conclusie
Tyler Lirio
93 Reputatie
1 Handleiding geschreven
USF Tampa, Team S11-G2, Cheng Spring 2018 Lid van USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 219
