Inleiding
Remove and replace a headlight bulb on the third-generation Dodge Ram 1500.
Wat je nodig hebt
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
Unscrew the second screw located approximately 6 inches below the first.
Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
Carefully pull the headlight bulb holder out of its socket.
If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
What is that rubber gasket called or a part # please, mine is all torn from previous owner
