Ga door naar hoofdinhoud
Havoc Heli IR LED Replacement
Wat je nodig hebt
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: stap 1, afbeelding 1 van 2 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: stap 1, afbeelding 2 van 2
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
  2. Havoc Heli IR LED  Replacement: stap 2, afbeelding 1 van 3 Havoc Heli IR LED  Replacement: stap 2, afbeelding 2 van 3 Havoc Heli IR LED  Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
  3. Havoc Heli IR LED  Replacement: stap 3, afbeelding 1 van 3 Havoc Heli IR LED  Replacement: stap 3, afbeelding 2 van 3 Havoc Heli IR LED  Replacement: stap 3, afbeelding 3 van 3
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
  4. Havoc Heli IR LED  Replacement: stap 4, afbeelding 1 van 1
    • Lift up the red IR LED cover to remove it.
  5. Havoc Heli IR LED  Replacement: stap 5, afbeelding 1 van 2 Havoc Heli IR LED  Replacement: stap 5, afbeelding 2 van 2
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
  6. Havoc Heli IR LED  Replacement: stap 6, afbeelding 1 van 2 Havoc Heli IR LED  Replacement: stap 6, afbeelding 2 van 2
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael Kent
128 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 1-13, Lauer Fall 2016 Lid van Michigan Tech, Team 1-13, Lauer Fall 2016
MTU-LAUER-F16S1G13
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 552
