Ga door naar hoofdinhoud
Hasbro Bop-It Micro Series Speaker Replacement
Wat je nodig hebt
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: stap 3, afbeelding 1 van 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Hasbro Bop-It Micro Series Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: stap 5, afbeelding 1 van 1
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
Conclusie
Follow the steps of this guide in reverse to reassemble.
Glenn Haag
479 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-1, Harley Fall 2016 Lid van IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 1,257
