Ga door naar hoofdinhoud
Hasbro Bop-It Micro Series Buttons Replacement
Wat je nodig hebt
  1. Hasbro Bop-It Micro Series Buttons Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Buttons Replacement: stap 3, afbeelding 1 van 1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Buttons Replacement, Buttons: stap 4, afbeelding 1 van 1
    • Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
  5. Hasbro Bop-It Micro Series Buttons Replacement: stap 5, afbeelding 1 van 1
    • After removing the buttons, solder new, operational buttons back into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Glenn Haag
479 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-1, Harley Fall 2016 Lid van IUPUI, Team 3-1, Harley Fall 2016
IUPUI-HARLEY-F16S3G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 1,893
