Ga door naar hoofdinhoud
Harman Kardon Onyx Studio 2 Front Panel Replacement
Wat je nodig hebt
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: stap 2, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: stap 2, afbeelding 2 van 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: stap 4, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
Conclusie
To reassemble, follow these steps in reverse order.
Alexandra Achtenberg
2.046 Reputatie
6 handleidingen geschreven
USF Tampa, Team 16-5, Blackwell Spring 2017 Lid van USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Leden
24 handleidingen geschreven
Één opmerking
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 61
Altijd: 6,069
