Ga door naar hoofdinhoud
Harman Kardon Onyx Studio 2 Circuit Board Replacement
Wat je nodig hebt
  1. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: stap 1, afbeelding 1 van 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: stap 1, afbeelding 2 van 3 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 2, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 4, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Control Board: stap 5, afbeelding 1 van 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 6, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 7, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: stap 8, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement, Circuit Board: stap 8, afbeelding 2 van 2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 9, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Circuit Board Replacement: stap 9, afbeelding 2 van 2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Alexandra Achtenberg
2.046 Reputatie
6 handleidingen geschreven
USF Tampa, Team 16-5, Blackwell Spring 2017 Lid van USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Leden
24 handleidingen geschreven
5 opmerkingen
Where do I get another one
Adrian tlahuel - Antwoord
Where we buy the board?
Eric Therrien - Antwoord
Umm… this was rather anticlimactic. Last step was basically like “and now contemplate your life choices”.
markcendan - Antwoord
Where can I Buy a new hk onix studio Main board?
tecnologia en localizaciòn - Antwoord
My speaker was working great. I just disconnected my phone to make a call, put YouTube back on it was all mumbled & the big button in the back kept pulsing so fast.
Maureen Field - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 128
Altijd: 21,568
