Ga door naar hoofdinhoud
Harman Kardon Onyx Studio 2 Battery Replacement
Wat je nodig hebt
  1. Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: stap 1, afbeelding 1 van 3 Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: stap 1, afbeelding 2 van 3 Harman Kardon Onyx Studio 2 Battery Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Battery Replacement: stap 2, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Battery Replacement: stap 4, afbeelding 1 van 2 Harman Kardon Onyx Studio 2 Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Battery Replacement, Battery: stap 5, afbeelding 1 van 3 Harman Kardon Onyx Studio 2 Battery Replacement, Battery: stap 5, afbeelding 2 van 3 Harman Kardon Onyx Studio 2 Battery Replacement, Battery: stap 5, afbeelding 3 van 3
    • Begin by removing the three 10.4 mm T10 Torx screws from the battery cover.
    • Remove battery cover.
    • Pull battery out to replace.
Conclusie
45 andere personen hebben deze handleiding voltooid.
Alexandra Achtenberg
2.046 Reputatie
6 handleidingen geschreven
USF Tampa, Team 16-5, Blackwell Spring 2017 Lid van USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Leden
24 handleidingen geschreven
21 opmerkingen
Thanks for the step by step instructions. I have tried replacing the batteries but the speaker still won't turned on. I believe the battery cable/module is broken, do you know how to fix it? Thanks.
Wompy Pratomo - Antwoord
Can you put a step by step instruction how to replace a battery on a Harman/ Kardon esquire 2?
Bullet Magnet - Antwoord
Hello, what kind of battery is good for replacement? I'm thinking of using LG 3000mAh or Panasonic 3400 mAh (both unprotected) and making a direct swap. Help please
marcel - Antwoord
Can you tell me what kind of the hk onyx speaker battery's, if you can show me step instructions to replace! Thankyou!
happymandm8 - Antwoord
This worked great. Thanks. Battery would not charge. Bought a replacement on Ebay and now it works as if new.
JSM - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 122
Afgelopen 30 dagen: 403
Altijd: 88,330
