Inleiding
This guide will help you to replace the power port of Harman Kardon Invoke. You may replace the power port if you faced a weak port that will affect the efficiency of the Invoke or a broken/old port that prevents the invoke from connecting to power. By replacing the power port, the Invoke should be connecting to the power perfectly.
Wat je nodig hebt
Grip the bottom firmly and wiggle upwards to remove it.
Use a T10 Torx screwdriver to remove two 10 mm screws from the board that is attached to the ports.
Pull the board up lightly.
Één andere persoon heeft deze handleiding voltooid.
