Ga door naar hoofdinhoud
Harman Kardon Esquire Mini Speaker Replacement
Wat je nodig hebt
  1. Harman Kardon Esquire Mini Speaker Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Pull out the motherboard by removing 4 screws around the perimeter of the motherboard. Keep in mind the wires still attached to the speakers, so pull gently.
  4. Harman Kardon Esquire Mini Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using the PH0 screwdriver unscrew the screws, there is one 4 mm screw on each speaker.
    • Re-do the same steps above for the other speaker to remove it.
  5. Harman Kardon Esquire Mini Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the speaker by using the plastic opening tool. Apply a gentle upward force to remove it.
Conclusie
15 andere personen hebben deze handleiding voltooid.
yousef aljeemaz
1.039 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G9, Cagle Fall 2017 Lid van USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Leden
39 opmerkingen
Where can i buy a new speaker for this sound box ? thanks… sizinojr@gmail.com
Sizino Santos - Antwoord
Did you ever find the replacement speaker? I need one too.
Thx.
Troy -
Thanks, I need speaker also, where can I buy.
mnyucel@yahoo.com
mnyucel - Antwoord
Hi, I also need to know where could get new replacement speaker.
Thanks
mezafernando23 -
Hi, I also need to know where could I get the replacement speaker.
Thanks
mezafernando23 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 174
Altijd: 19,127
