Ga door naar hoofdinhoud
Harman Kardon Esquire Mini Front Panel Replacement
Wat je nodig hebt
  1. Harman Kardon Esquire Mini Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
yousef aljeemaz
1.039 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G9, Cagle Fall 2017 Lid van USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 676
