Inleiding
This guide will show how to remove the old spark plugs, check the new spark plugs for installation, prepare the spark plugs for installation, and reinstall the new spark plugs.
  1. The spark plugs are easy to spot on the left side of the motorcycle.
    • The spark plugs are easy to spot on the left side of the motorcycle.
    • The procedure for removing the spark plugs is the same for both the front and back cylinder, and either spark plug can be replaced first. This guide will show how to remove and install the spark plug in the rear cylinder.
  2. Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire. Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
    • Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. Use an 11/16" spark plug socket to unscrew the spark plug by turning in a counter-clockwise direction. Some aftermarket spark plugs that fit the Sportster use a slightly larger 18mm spark plug socket.
    • Use an 11/16" spark plug socket to unscrew the spark plug by turning in a counter-clockwise direction.
    • Some aftermarket spark plugs that fit the Sportster use a slightly larger 18mm spark plug socket.
    • Remove the spark plug from the cylinder.
  5. Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches. If they are not pre-installed, make sure that the crush washer and terminal nut are installed. If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
    • Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches.
    • If they are not pre-installed, make sure that the crush washer and terminal nut are installed.
  6. Using your fingers, install the new spark plug into the socket, and hand tighten until firm. Using a torque wrench, tighten the spark plug to the proper specification.
    • Using your fingers, install the new spark plug into the socket, and hand tighten until firm.
    • Using a torque wrench, tighten the spark plug to the proper specification.
    • When installing spark plugs, proper torque can be important. To loose and they could rattle out or leak; too tight and you can strip your cylinder head. The correct torque for this plug is between 90 and 120 inch lbs.
  7. Reinstall your spark plug wire by pushing it firmly onto the new plug.
    • Reinstall your spark plug wire by pushing it firmly onto the new plug.
    • Make sure that it seats properly. You can usually feel a definitive click when it is installed correctly.
Conclusie
Be sure to repeat the above procedure for the remaining cylinder.
14 andere personen hebben deze handleiding voltooid.
Eric Essen
16.002 Reputatie
8 handleidingen geschreven
iFixit Lid van iFixit
Community
104 Leden
8.342 handleidingen geschreven
Just for information, particularly in the UK, you may be able to purchase sparking plugs cheaper at a Chandlers, as there are quite a few 4-stroke outboard engines use these plugs.
BigRoj - Antwoord
How do you do this with a XL1200S with dual spark plug heads??
Andy - Antwoord
Couldn't have made it any simpler
Matt Pramik - Antwoord
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
mrjacecabezut - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 49
Afgelopen 7 Dagen: 306
Afgelopen 30 Dagen: 1,234
Altijd: 44,180
