Ga door naar hoofdinhoud
Harley-Davidson Sportster Evolution Oil Change
Wat je nodig hebt
  1. Harley-Davidson Sportster Evolution Oil Change, Preparation: stap 1, afbeelding 1 van 3 Harley-Davidson Sportster Evolution Oil Change, Preparation: stap 1, afbeelding 2 van 3 Harley-Davidson Sportster Evolution Oil Change, Preparation: stap 1, afbeelding 3 van 3
    • Securing the bike in an upright position allows for easier access to the drain tube.
    • Always make sure your work area is clean and you have plenty of room to work safely. Never start or run your motorcycle indoors.
  2. Harley-Davidson Sportster Evolution Oil Change, Draining the Oil: stap 2, afbeelding 1 van 3 Harley-Davidson Sportster Evolution Oil Change, Draining the Oil: stap 2, afbeelding 2 van 3 Harley-Davidson Sportster Evolution Oil Change, Draining the Oil: stap 2, afbeelding 3 van 3
    • Unlike most vehicles, the Harley Sportster Evolution Engine has an oil drain tube, not a plug.
    • This tube is attached by a house clamp to a nipple welded to the frame.
    • Loosen the house clamp with a Flathead Screwdriver. Do not remove the tube until you have your drain pan in position.
    • Removing the cap/dipstick from your oil tank at this point may help your oil drain faster.
    • Pull the hose free from it's nipple and allow the oil to drain into your drain pan.
    • When the oil slows to a drip, replace the hose. Do not tighten the clamp yet, we will return for that later.
  3. Harley-Davidson Sportster Evolution Oil Change: stap 3, afbeelding 1 van 3 Harley-Davidson Sportster Evolution Oil Change: stap 3, afbeelding 2 van 3 Harley-Davidson Sportster Evolution Oil Change: stap 3, afbeelding 3 van 3
    • The oil filter is located at the front of the engine, between the frame downtube and front cylinder.
    • Move the oil pan to the front of the bike, directly underneath the oil filter.
    • Remove the oil filter. This may require an oil filter wrench.
    • If you don't have an oil-catcher, the oil will run down the frame, and get on some parts of the bike. There is no easy way to prevent this, so just wipe it down when it's done dripping.
  4. Harley-Davidson Sportster Evolution Oil Change, Installing the New Oil Filter: stap 4, afbeelding 1 van 3 Harley-Davidson Sportster Evolution Oil Change, Installing the New Oil Filter: stap 4, afbeelding 2 van 3 Harley-Davidson Sportster Evolution Oil Change, Installing the New Oil Filter: stap 4, afbeelding 3 van 3
    • Open 1 quart of oil. Pour it into the filter until the filter is about 1/2 full.
    • Apply a small amount of clean oil to the rubber gasket on the new oil filter.
    • Wipe down the oil filter mounting area, and any oil residue that has run down onto the motorcycle.
    • Make sure that the old gasket came off with the filter, and you have a clean smooth surface to install the new filter on.
  5. Harley-Davidson Sportster Evolution Oil Change: stap 5, afbeelding 1 van 1
    • Carefully thread your new oil filter into place, turning it in a clockwise direction. Do not overtighten your filter. Only turn the filter a 1/2 turn past the point where you start to feel resistance from the gasket contacting the engine.
  6. Harley-Davidson Sportster Evolution Oil Change, Re-installing the Drain Tube: stap 6, afbeelding 1 van 2 Harley-Davidson Sportster Evolution Oil Change, Re-installing the Drain Tube: stap 6, afbeelding 2 van 2
    • Move the drain pan back underneath the oil drain tube. By this time more oil will have collected in it. Remove the tube again, and allow it to run out until it is just a light drip.
    • Reinstall the oil drain tube on its nipple, tightening the hose clamp with a flathead Screwdriver.
  7. Harley-Davidson Sportster Evolution Oil Change, Adding New Oil: stap 7, afbeelding 1 van 3 Harley-Davidson Sportster Evolution Oil Change, Adding New Oil: stap 7, afbeelding 2 van 3 Harley-Davidson Sportster Evolution Oil Change, Adding New Oil: stap 7, afbeelding 3 van 3
    • Pull the oil cap/dipstick off of the oil tank.
    • Some models will require the cap to be twisted first, then pulled. If you are not sure what model you have, work carefully and gently, making sure to not damage anything.
    • Using your funnel, slowly pour 3 quarts of oil into your oil tank.
    • Although the Evolution engine holds up to 3.5 quarts after a rebuild or when filled new, only 3 get replaced during the oil change.
    • Use the oilcap/dipstick to check your engine oil level (holding the bike level if you have been working with your side-stand). You oil level should be kept between the 2 dipstick marks. After refilling with 3 quarts it should be right to the top one.
Conclusie
It is a good idea to start your engine and let it run for a few minutes. Check your drain tube and oil filter for leaks. Recheck your oil level, and adjust if needed.
87 andere personen hebben deze handleiding voltooid.
Eric Essen
17.804 Reputatie
8 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
33 opmerkingen
One of the most helpful guides on a sportster oil change.
brandon christian - Antwoord
You may be able to use a Form-A-Funnel (Pig Funnel) to catch the oil from the filter.
http://www.formafunnel.com/buyNow.html
IF(!) I owned a Hardley like this, i would keep an eye on the drain hose for deterioration or road debris damage, and probably carry a spare hose. Also, a vandal could loosen the clamp or cut the hose.
George - Antwoord
Very helpful, simple instruction, good pictures
Howard Brewer - Antwoord
Best oil change I've read. Easy and hard to make mistakes. A+
Phillip Esquibel -
Eric Essen: G. bless your generations forever. Manu, Brazil.
Manu Costa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 62
Afgelopen 7 dagen: 421
Afgelopen 30 dagen: 1,782
Altijd: 318,940
