Ga door naar hoofdinhoud
Hard Reset
  1. Hard Reset, Hard Reset: stap 1, afbeelding 1 van 1
    • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
  2. Hard Reset: stap 2, afbeelding 1 van 2 Hard Reset: stap 2, afbeelding 2 van 2
    • When the screen powers on, you will see an instructional message.
    • Press the volume up button to perform the hard reset.
    • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
  3. Hard Reset: stap 3, afbeelding 1 van 1
    • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
  4. Hard Reset: stap 4, afbeelding 1 van 2 Hard Reset: stap 4, afbeelding 2 van 2
    • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
Conclusie
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
7 andere personen hebben deze handleiding voltooid.
Lucas David
540 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-13, Maness Spring 2013 Lid van Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Leden
18 handleidingen geschreven
Één opmerking
great information thanks.
regards
Jrubio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,523
